insert start/finish into data?
bellcoupe
Post by bellcoupe »
Is it possible to insert a start/finish marker into the data from a session to break apart a pair of laps where the system didn't pick up the start line? My best 2 laps at Putnam Park had this issue. I can see from the total elapsed time for the 2 laps that they were ones I'd like to use the Export function on, to have the data analysis and video saved - but ideally as single laps, not a pair together in one video file.
This is on Android Petrolhead v23.0.5.
Re: insert start/finish into data?
Please see the FAQ viewtopic.php?f=39&t=2&p=2#p2 for instructions on how to split recordings after the fact.
bellcoupe
Post by bellcoupe »
Thanks for the fast response, Harry!
I was able to split the laps. However, the lap times are not correct. For a pair of laps totaling approximately 2:41, it split them into 1:25:30 and 1:15:30. Looking at the elapsed times on the video at start/finish for those laps, each should be near 1:20:30.
Had to use a very wide detection setting (120m), so perhaps the data just isn't accurate enough on this pair of laps to get the split properly placed?
This sounds like bad data (at least) around the start / finish. I can’t say a lot more without looking into the actual data. But I’m pretty sure the calculation is sound with respect to the data collected (which isn’t reality as we all know).
Please check your smartphone’s mounting position. It is shown in illustration #3 of LapTimer’s Quick Reference.
