Harry wrote: Thu Sep 05, 2019 7:17 am
You can record engine data with or without Engine View. To do this, enable Manual Timing in LapTimer’s Settings. This will give you Start / Stop buttons in Timer and other views. You can use them to record arbitrary drives.
To analyze the data recorded in Excel, export the recording to CSV. It includes GPS, IMU, tires, and engine data.
Engine View is a real time display of engine / OBD data. It is an extensive and detailed display of most channels retrieved from OBD.
Of course you already had a solution. Thanks Harry. I'll try it this morning.
