I see that on the supported device list there's the APEX Pro unit, but when I try to connect to it purely through the Android version of Harry's Laptime Petrolhead I don't see it/can't connect to it.
Thanks for your time and assistance
Apex PRO use with Android
accordionfolder
Re: Apex PRO use with Android
23.0.6 required for this integration. For iOS, it is available already. For Android, I will require some more days / weeks. I need to add 64Bit support - which is complicated as I need to migrate to a new tool chain.
accordionfolder
Ah, are you using Cmake or the standalone toolchain? Cmake is worth the time investment - We recently dealt with our native code's 64bit migration.
Good to hear it will be included eventually - I feared it was an iOS only feature. I've upgraded to GrandPrix. Thanks for your hard work.
Cmake for LapTimer native code and the standalone tool chain for the external video library.
