How to Recalculate / Verify Lap?
DapperDanMan
Post by DapperDanMan »
I recently purchased HLT and took it to a track event at Atlanta Motorsports Park.
Both of my ~15-minute sessions were recorded as a single lap. Through searching I found references to functionality where after altering some advanced settings I could try to use a recalculate menu and verify lap function to hopefully resolve the issue. Unfortunately I've been unable to find this functionality.
This is what my Data Recording section looks like for one of the laps.
What am I missing?
As a side note, I've been told by multiple sources that Harry's no longer works well at AMP, I'm hoping someone could look at the track data and see if there's anything obvious that needs to be corrected.
Re: How to Recalculate / Verify Lap?
The technical functions have been moved down the view hierarchy. All the recalculate functions are now located in LapTimer ‣ Analysis ‣ Lap List ‣ any lap ‣ Fixes. Press the second icon in the bottom to get a list of recalculations available (including tire temperature simulation).
On AMP: according to the data you have sent in parallel, the S/F line for AMP is positioned perfectly. We will check driving direction as the second important parameter for trigger detection.
Screen Shot 2019-08-08 at 10.51.49.png (1.9 MiB) Viewed 9852 times
We have found the problem with AMP... The problem is about the third split shortly ahead of s/f. Whenever LapTimer hits a tigger (like split or s/f), it pauses detection for 2 or 3 seconds. So the faster you driver, the higher the probability s/f will be missed because LapTimer is paused from split 3. The quick work around is to remove the Split 3 from the track set (Lap List ‣ ATLANTA MP ‣ Certified Track Set ‣ Split 3 ‣ Delete.
We will update the track set shortly and post it here on the forum and on Facebook. I see quite a lot of "multi lap times" in the Hall of Fame for AMP - so several users were affected.
I'm sorry and thanks for the feedback.
mr.woz
Post by mr.woz »
Im having a similar issue with a day at Cadwell Park. Ive followed the steps to increase to wide corridor all the way up to 200m and recalculated using the settings above but it is still not splitting my laps down. What is the issue here?
The AMP issue discussed occurs when recognizing laps in real time. It does not occur for Recalculate ‣ Verify Lap. In case increasing the corridor to 200m and Deviation Directed Trigger to 90 doesn't help, I assume the data quality is very bad. How does the line driven look for your Cadwell recording? Please have a look into Lap List ‣ your multi lap ‣ Data Recordings / Preview.
Keenanlog
Probleme mit der Laperfassung in Harry's GPS Suite**.
Post by Keenanlog »
Ich habe festgestellt, dass meine Sessions nicht korrekt als separate Runden aufgezeichnet werden. Gibt es spezielle Einstellungen oder Schritte, die ich befolgen kann, um die Laperfassung zu überprüfen und gegebenenfalls zu korrigieren? Ich wäre dankbar für Tipps oder Anleitungen, die mir helfen können, diese Funktion besser zu nutzen.",
"refusal
Re: Probleme mit der Laperfassung in Harry's GPS Suite**.
Keenanlog wrote: Sat Sep 28, 2024 2:11 pm Ich habe festgestellt, dass meine Sessions nicht korrekt als separate Runden aufgezeichnet werden. Gibt es spezielle Einstellungen oder Schritte, die ich befolgen kann, um die Laperfassung zu überprüfen und gegebenenfalls zu korrigieren? Ich wäre dankbar für Tipps oder Anleitungen, die mir helfen können, diese Funktion besser zu nutzen.
Die Anleitung zum nachträglichen Splitten in Runden steht in meiner ersten Antwort in diesem Thema.
