Oil Temperature OBD?
Re: Oil Temperature OBD?
On the former discussion: LapTimer v23 had a bug for custom PID requests in the Android implementation. It should be fixed for v23.0.1.
PitrsRS
Post by PitrsRS »
thanks, and what about syntax of formula in HLT? for example for fuel imput is it 100/255A (see on picture). So how I can set it in HLT? like =(100/255)A or just =100/255A or any else option?
2016 SEAT Leon CUPRA 290 ST
Here is the full syntax for expressions in LapTimer:
Code: Select all
               formula                 =   [ "=" ] conditionalexpression
               conditionalexpression   =   equalityexpression { "?" equalityexpression ":" equalityexpression }
               equalityexpression      =   relationalexpression { "=="|"!=" relationalexpression }
               relationalexpression    =   expression { "<"|">"|"<="|">=" expression }
               expression              =   [ "+"|"-" ] term { "+"|"-" term }
               term                    =   exponent { "*"|"/" exponent }
               exponent                =   factor { "^" factor }
               factor                  =   parameter|number|"(" conditionalexpression ")"
               integer                 =   "0"|...|"9" { "0"|...|"9" }
               number                  =   integer [ "." { "0"|...|"9" } ]
               parameter               =   "A"|...|"Z" { "A"|...|"Z" } [ bitqualifier ]
               bitqualifier            =   integer
So you better use "=100/255*A". Brackets are not required, evaluation for a <term> is left to right.
PitrsRS
Post by PitrsRS »
just like that? Im not sure about Mode, which I should use 21, 22 or 23
You will need an ECU selection at least. Formally that's fine otherwise, but I cannot comment on any custom PID setting for Skodas.
PitrsRS
Post by PitrsRS »
Ok thanks, I´ll try it in car and then I´ll give you feedback ;)
Do you have a valid source for Skoda PIDs? Which one is it? Please keep in mind that custom PIDs are different for every manufacturer and even model. So you can't use a custom PID spec from other cars.
PitrsRS
Post by PitrsRS »
Unfortunately I dont, I spent several hours to find anything but without success. Or, its possible to use VCDS cable and SW (I already have it) to dig some info about it directly from car?
PitrsRS
Post by PitrsRS »
Hi Harry. I´ve tried to check oil temp via VCDS and I can see correct value. Can I use VCDS data to find optimal PID settings for HLT? Or it´s nonsense?
I have no experience or insights into the VCDS tool. Someone else to help?
