Exporting A Session with All Lap Data
msnare
Post by msnare »
When I export a single lap's data in CSV format I get a ton of detailed data including lat, long. speed, etc., at approx 1,300 data points (showing as 1,300 lines in Excel) in a 2 minute lap. When I export a whole session of laps, even a small session with 4 or 5 laps, I get a lap time, split times, and a few other bits, which show up as a single "summary" line per lap.
Is there a way to export a whole session and get the same detail I get with a single lap export? I know I could export each lap and merge the data manually, just hoping there is a more automated way.
If it matters, I want to import what I export into a tool like Track Attack that I can use to do analysis on my laptop, compare multiple laps, see multiple charts on same screen, etc.
Thanks.
Re: Exporting A Session with All Lap Data
When exporting to CSV, LapTimer generates one or two files depending on the number of laps included:
1 lap: LapTimerGPSRecDB.csv
multiple laps: LapTimerDB.csv and LapTimerGPSRecDB.csv
LapTimerDB.csv (if exported) has a list of laps, while LapTimerGPSRecDB.csv always has the full details.
msnare
Post by msnare »
OK, so you are saying that the only way to get the full details for a multi-lap track session is to export one lap at a time and then either manually paste the laps together into a single file, or import them one lap at a time into another app. Have I got this right?
That works OK, but it would be a nice feature to be able to export full details of a whole session in a single export file. Thanks.
No, what I'm saying is you need to look into the right file. ;-) Check LapTimerGPSRecDB.csv instead of LapTimerDB.csv. The later is an extra you get for multi-lap exports.
If you can't remember which name is which, check the file size and open the larger one.
msnare
Post by msnare »
Thanks. Works as you say when I try again. I must have been only selecting a single lap when I thought I was selecting the full session.
