Your "exposure lock" setting could be used to correct for this but the user would have to aim the camera down at the track to lock in on the darker track surface. With a camera mount carefully aimed correctly, this is another pre-session task that could be hard to fit into a driver's check list of things to do.
Is there a way for your programming to control light exposure based on the bottom half of the image, rather than the default averaging that the camera uses automatically ?
UNDER-EXPOSED TRACK ACTIVITY
