Hi Folks;
I keep getting a yellow alert with the OBD Update Rate. I am using the Kiwi3 and did the Firmware update for IOS. It appears my data is showing up correctly, but I still am wondering if something is not right.
** Can someone tell me if this is an issue, not an issue, what the problem is, why it's happening ?
B-Stead
OBD Update Rate - Help ???
- IMG_7781.PNG (67.15 KiB) Viewed 1431 times
- IMG_7838.PNG (218.94 KiB) Viewed 1431 times
- IMG_7779.PNG (59.84 KiB) Viewed 1431 times
Re: OBD Update Rate - Help ???
Looks like the car's bus is simply very slow. Please verify if you have other Bluetooth devices around slowing down thing in addition. Pleas ignore the warning otherwise.
No, I do not have other Bluetooth devices running at the same time. Thank you for getting back to me.
