Dropbox Export doesnt work
When I attempt to export to my Dropbox account I get a message saying unable to export but no further description. I checked my Dropbox account configuration and HLT is listed as an app with access but under access type it says "No access - App folder deleted". How do I recreate the app folder so I can export all my data?
Re: Dropbox Export doesnt work
Please check LapTimer -> Administration -> Settings -> Expert Settings. You will find a "Reset Dropbox" here. Please turn it on and restart the app. Next time you export data, you should be prompted to log in again. I assume the missing folder is created then.
worked = thanks Harry!
francis-le-varois
- 10 or more Posts ★
hello Harry,
sorry to digup this subject...but I tried to use the dropbox export and seems not to properly work.
actually, when I send only one file, it works. but when there are several (like "all" selected), it doesn't work. I got an error message.
What's your opinion ?
many thanks.
many thanks.
In case it works for one lap but not for many, the size is too big. Dropbox exports are uncompressed currently, so sizes go up pretty fast. Especially for .kml and .hlptrl.
francis-le-varois
thanks for the answer.
but do you know why (while it's going with the files one by one) the size does matter with all files together ?
