Connecting a bluetooth ODB + GPS
NeoJFK
Post by NeoJFK »
sorry for asking but i cant figure out if this possible or not
I currently have a Sony Xperia Z5 and i already ordered a Bluetooth ODB sensor but i woudl like ot also have an external GPS antenna.
thanks for your help,.
Re: Connecting a bluetooth ODB + GPS
Yes, you can connect multiple BT devices at a time. They will share the bandwidth available, but it is usually enough to not limit one of them.
NeoJFK
Post by NeoJFK »
Hi Harry and thanks for the quick answer.
So i can connect both an bluetooth gps antenna + the ODB blueooth ??? it seems akward that the phone will connect to 2 devises at the same time.
I already bought the recommended OBDLINK MX BLUETOOTH
Now which GPS bluetooth antenna would be recommended for my sony? but this is only if you are sure that can connect to 2 devices at the same time. I dont even understand how it would be possible as everytime i select one bluetooth device on the list the phone will disconnect from the existing one
That's part of the Bluetooth specification and is working. :-)
Recommended GPS accessories are listed on www.gps-laptimer.de/compatibility/android
NeoJFK
Post by NeoJFK »
Thanks harry! Last question. Would this be compatible with 1 or 2 Go Pros ?
You can join one WiFi network on top of the BT connections. So 1 HERO - yes, 2 HEROs - no. That's a general limitation with action cams currently. They create their own networks. In case you want to control more than one, GoPro's remote control is needed - it uses some proprietary network protocol.
NeoJFK
Post by NeoJFK »
i have the remote but i guess that would not be started by HLT anyway right? I will just start the back cam manually no big deal
thanks Harry
NeoJFK
Post by NeoJFK »
very very last question. If i am connect to the wifi for the gopro then the phone wont have internet right hence no gps? so how do you make that work /
LapTimer does not need Internet access to work. Just make sure you load your track set at home are while the GoPro is not connected. In case you are experienced with network configurations, you can configure it in a way the GoPro is not set as the default gateway. This will allow the phone to access the Internet using mobile data while being connected to the GoPro.
NeoJFK
Post by NeoJFK »
Thanks Harry will try that! and will post a feedback as well!
