Help Galaxy S5 Neo
kimgrace
Help Galaxy S5 Neo
Post by kimgrace »
I recorded a couple of trackdays with video, but when exporting overlay GPS/Accell. & OBD are not in sync.
I should be able to edit the sync between video and GPS data, but that feature simply does not work on my phone.
(Video frame does not advance, I assume until next full-frame in the video stream, or it displays [No Video]...)
Running Android 5.1.1, Recorded on v.19, tried v.19 for export to no avail, and have now upgraded to v.20....
Is anyone else using a Galaxy S5 Neo, and successfully??
kimgrace
Re: Help Galaxy S5 Neo
Post by kimgrace »
Now updated to 20.0.1, still not working, and now seems to have new problems with "Master video not found" :-/ .......
Not sure it is a sync issue or something different.
So to start with: do you get an overlaid video (with bad sync between data and video)?
Has the video been recorded using one of the predefined tracks?
And is data too late or too early?
kimgrace
Post by kimgrace »
I do get overlaid video, in v.20 there's also a realtime preview.
Yes, predefined tracks. (Ring Djursland, Jyllandsringen, both in Denmark.)
Data is WAY early...
kimgrace
Post by kimgrace »
Uploading example to https://youtu.be/CB_czuiTWJ8
kimgrace
Post by kimgrace »
kimgrace wrote:Uploading example to https://youtu.be/CB_czuiTWJ8
This looks like half a second early to me? This in turn means video is half a second late and the Overlay Synchronization / Video value show be adjusted from standard 1.0 seconds to 1.5 seconds.
kimgrace
Post by kimgrace »
Where do I find the default values for the other sync values?
And is there a way to reset the the sync point relationship between GPS and video?
kimgrace
Post by kimgrace »
Now I can now longer render any thing...
"Master video either is not available, or misses the video or audio track..."
The preview works... (Still out of sync though.)
kimgrace wrote:Where do I find the default values for the other sync values?
They are 1.5 for GPS, 1.0 for OBD, 0.5 for Acceleration and 1.0 for Video. All of these delays are applied for automatic recordings establishing a standard relationship between data and video. In addition, you have full control on the relation and can set the sync point manually: got Lap Details and memorize the Lap #xy in the title bar. Touch the Video preview bringing you to Video Details. Scroll to the bottom and touch he row showing "Lap #xy ends at ...". In the dialog coming up, change the sync point to any frame you like. NB: this should be an exception and should not be necessary. Once device specific delays are adjusted, video should be fine out of the box.
For testing delay and sync points, you can use the real time overlay. It uses the same timing as the actual overlay export.
No idea on the Master missing - probably too much changed and some caching issue. Kill the app or reboot the phone and try again.
