[SOLVED] turning off "easy mode"?
psychoboy
Post by psychoboy »
i've found descriptions that suggest there is a message about turning off "easy mode" but i can't find the message or the method, here or in the app.
the section the toggle was in seems to go away in easy mode.
i'm sure i'm just overlooking it, thanks in advance for any heads up you can give.
justin
Re: turning off "easy mode"?
Goto the Assistant View and select 'Define User' again. Select Advanced mode here.
psychoboy
Post by psychoboy »
the one place i didn't look.
thanks!
looking forward to trying this thing out this weekend!
justin
