The screen shows "parallel requests supported", so this is a CAN setting? Please make sure CAN Multi Requests are set to Off in Expert Settings / OBD Tweaks. Please make sure you have the latest version of LapTimer installed too (19.0.16).
Automatic Gen II, HLT (GP Edition)
Re: Automatic Gen II, HLT (GP Edition)
I changed my settings to:
Non CAN bus vehicles:
LapTimer ‣ Administration ‣ Settings ‣ Expert Settings ‣ OBD Tweaks / Sequential Requests (BT1) ‣ ON
LapTimer ‣ Administration ‣ Settings ‣ Expert Settings ‣ OBD Tweaks / CAN Multi Requests (ELM327) ‣ OFF
I have v16 installed.
There is still no data being shown.
- IMG_3187.PNG (245.8 KiB) Viewed 5744 times
- IMG_3186_small.PNG (146.13 KiB) Viewed 5744 times
Please post your Sensor Information after disabling CAN Multi Requests.
I have tested the settings with the latest LapTimer and Automatic versions and it doesn't send multi request any more (as expected).
When starting LapTimer, are you asked to authenticate the Automatic (browser window) or does it just connect?
In case you do not get updates after having the CAN Multi Request set to Off, having the Automatic app and firmware updated to the latest version, and running LapTimer v19.0.16, please follow the instructions in viewtopic.php?f=39&t=1500 to generate a log of the communication. Please enable both the OBD Sensors and the Sensor Connection log / trace classes. Make sure you log everything from plugging in the Automatic adapter / running the engine, to the point in time you see the Automatic is connected but not showing data in Engine View or GPS View. You will use Harry's GPS Buddy to do this, so you will most probably not have the Engine View but an enhance GPS View.
Hi
I'm still not getting the data.
I followed the directions to send you a data trace.
Please let me know.
Thanks.
Please let me know.
Thanks.
- IMG_3195.PNG (169.48 KiB) Viewed 5724 times
CarbonCorsa
Any idea on a Android release?
