Lap data in analysis - lap list has changed since I have gone back to view this data a day after.
For example on "best lap" average speed is showing one figure in the lap listing (which is the correct and original figure i was viewing yesterday).
however when i enter that particular lap to view the details the average speed does not match and the rest of the figures have changed since yesterday. I can confirm this as I took a screenshot of the best lap figures and sent this to a friend on my phone.
Lap data changed - Iphone 5 - Petrolhead V19.0.7
Re: Lap data changed - Iphone 5 - Petrolhead V19.0.7
these are the screenshots I took before they changed, both before and after screenshots were for the best lap, the lap number has also changed from lap # 15 to 13.
as you can see the lap time has not changed but the map, speed traps and average speed has.
- image3.PNG (86.59 KiB) Viewed 2500 times
- image2.PNG (104.87 KiB) Viewed 2500 times
- image1.PNG (184.24 KiB) Viewed 2500 times
and this is viewing the day after, as you can see it showing correctly when your looking at the list of laps, but is not matching otherwise
- image6.PNG (87.41 KiB) Viewed 2500 times
- image5.PNG (99.05 KiB) Viewed 2500 times
- image4.PNG (159.72 KiB) Viewed 2500 times
This looks like the GPS recordings are not aligned any more with the lap list. The change in index might be a symptom for this too - maybe there have been 2 laps deleted which were recorded before 13/15 and the recording have not been adjusted accordingly. Maybe you can recall if there has been any operation, error message, crash? Anyway, please run these two steps:
1) Export you full list of laps to .hlptrl (bottom of Lap List, Transfer ‣ Export ‣ All / .hlptrl. This is just to make sure we will have access to your current database state in case we need it later.
2) Next, press Check Data available from the bottom of Lap List too. Besides many other things, this will check the lap / data alignment and correct it if possible.
Please let me know which message you get from 2 and how your data looks afterwards. You may export the one single fastest lap to .hlptrl again and send it to me for verification.
Harry it says "Database checked, no problems discovered"
shall i export the data via mail to you? What address shall i send it to?
I did also notice other data for other laps have changed from memory too. In fact it seems the maps have switched to be found in different laps
Please send the export to Harry@gps-laptimer.de Please export the one lap discussed only. In case I need more, I will come back.
Thanks Harry I have sent this
