Samsung Galaxy S4 problem with video record
PitrsRS
Post by PitrsRS »
I have a problem with video record on my Samsung Galaxy S4 (i9505). HLT ver 18.3.8
When I turn on "Lock Autofocus" and "Lock Exposure", this don´t work. These functions are still active, and phone tries to focus picture between front window and front of the car. With exposure is it same.
This weekend I was for the first time on Nordschleife and I want to record few laps, but phone/app does what he want.
2016 SEAT Leon CUPRA 290 ST
Re: Samsung Galaxy S4 problem with video record
I'm not sure if the S4 treats exposure and focus lock as hints. Late iOS devices do this - whenever they "believe" the lock is wrong, they start to refocus. I will check if there are more settings available in recent Android versions - which one do you use?
PitrsRS
Post by PitrsRS »
I have petrolhead version (in plan is GP ver). Previously i have Sony Xperia P (LT22i) with Jelly Bean android and on this phone these functions work's fine.
On my i9505 I have KitKat android.
Yes iOS and Android follow each other - not always the best solution for us track guys...
PitrsRS
Post by PitrsRS »
So, you think there is problem with KitKat? Do you have tested new Lolipop?
No, I haven't tested individual Android version for locked focus losses... The later the "smarter" they believe they are...
PitrsRS
Post by PitrsRS »
I have a idea to use GoPro cam, but GP version for Android is not released yet, and i dont want to buy another expensive iOS device only for this.
Now I'm back in Czech Rep, so maybe next year it will be better situation and app/phone will work fine.
Android GP is almost ready, 1 or 2 days ;-)
PitrsRS
Post by PitrsRS »
One more question.
This weekend we has 3 drivers in same car and we changed between laps. So, for every run I change name of driver, but when I do overlay, app put into overlay only last active name, not name wich I set before every lap. It´s normal behavior or I do mistake in something?
Yes, the driver is a global setting, nothing stored in lap level. In case you want to keep track of the drivers, you may use custom tags (check Lap Details / Status section) - one for each driver. However, the overlay always uses the global name so it needs to be adjusted for each lap.
