Video Overlay from GoPro to Android Device
Daffy_ED9
Post by Daffy_ED9 »
Hy LHT Community,
i´ve already red a lot about the video overlay, but i´m not able to manage it properly :-(
I´m using a HTC One mobile with Laptimer, in addition i have a GoPro Hero 2 HD for video filming.
When i try to overlay a film within HLT I can choose the video ( preview picture is available ) but i already get a red screamer and the information that the Vid is 0 seconds long and is ubnknown. When trying to open it, i get an error saying Mediatyp not supported.
I tried several formats with several programs, all didn´t bring me the selected success.
When exporting the vid and the HLT files i could easy create a vid with Racerender, but the Layout of the gauges is not that beautiful like in HLT.
What else can i try, to overlay the vid with an Android phone and HLT?
Thanks in advance for your help
Re: Video Overlay from GoPro to Android Device
The video in question has been recorded using the HERO2 or using HLT on HTC One?
Sounds like a video format incompatibility... What is the file size of the video?
Daffy_ED9
Post by Daffy_ED9 »
thanks for your quick reply.
Video was taken with the Gopro,
size is roughly somethin about 500mb for this lap. ( NOS BTG )
I already tried different resolutions and formats ( for example mp4 predefined for iphone, wmv for hd videos )
For this lap, or overall? For the current version of LapTimer [Android], the overall file size needs to be 2 GB or smaller. For the upcoming v19, this limit will most probably go away. In case you have ffmpeg installed on your desktop, please post what
Code: Select all
ffmpeg -i <VIDEOFILE>
says.
Daffy_ED9
Post by Daffy_ED9 »
Anbei die Infos der beiden Videos :
>ffmpeg -i d:\trackday\1.mp4
ffmpeg version N-71959-g9253cc4 Copyright (c) 2000-2015 the FFmpeg developers
built with gcc 4.9.2 (GCC)
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av
isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
le-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --
enable-libdcadec --enable-libfreetype --enable-libgme --enable-libgsm --enable-l
ibilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enab
le-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --en
able-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --ena
ble-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc
--enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enabl
e-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-lzma --ena
ble-decklink --enable-zlib
libavutil 54. 23.101 / 54. 23.101
libavcodec 56. 37.102 / 56. 37.102
libavformat 56. 32.100 / 56. 32.100
libavdevice 56. 4.100 / 56. 4.100
libavfilter 5. 16.101 / 5. 16.101
libswscale 3. 1.101 / 3. 1.101
libswresample 1. 1.100 / 1. 1.100
libpostproc 53. 3.100 / 53. 3.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'd:\trackday\1.mp4':
Metadata:
major_brand : mp42
minor_version : 1
compatible_brands: mp42isom
creation_time : 2015-04-26 20:58:42
Duration: 00:09:00.91, start: 0.000000, bitrate: 8120 kb/s
Stream #0:0(eng): Video: h264 (Main) (avc1 / 0x31637661), yuv420p, 1920x1080
[SAR 1:1 DAR 16:9], 8013 kb/s, 29.97 fps, 29.97 tbr, 29970 tbn, 59.94 tbc (defa
ult)
Metadata:
handler_name : AVID Video Handler
encoder : mpegable
Stream #0:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, flt
p, 99 kb/s (default)
Metadata:
handler_name : AVID Audio Handler
At least one output file must be specified
Und Video 2 ( gleiche Datei anders konvertiert )
>ffmpeg -i d:\trackday\2.wmv
[wmv3 @ 00000000003552e0] Extra data: 8 bits left, value: 0
Guessed Channel Layout for Input Stream #0.0 : stereo
Input #0, asf, from 'd:\trackday\2.wmv':
Metadata:
DeviceConformanceTemplate: SP
IsVBR : 0
MediaFoundationVersion: 2.112
Duration: 00:09:00.94, start: 0.000000, bitrate: 8175 kb/s
Stream #0:0(eng): Audio: wmav2 (a[1][0][0] / 0x0161), 48000 Hz, 2 channels,
fltp, 128 kb/s
Stream #0:1(eng): Video: wmv3 (Simple) (WMV3 / 0x33564D57), yuv420p, 1920x10
80, 8013 kb/s, SAR 1:1 DAR 16:9, 29.97 fps, 29.97 tbr, 1k tbn, 1k tbc
The first video reports 9 minutes length and a video bitrate of 8192 kb/s which should make a file around 500MB. There is nothing wrong for this description... The second video will not be recognized by LapTimer as it comes with a .wmv extension (although the video lib will most probably be able to process it).
I'd suggest to try it again once v19 gets available. It comes with a new version of the video lib and no 2GB limit...
Please give me 1 or 2 days (depends on other stuff, not the android app) and it will be available.
In case it fails again, we will check the log for the exact issue.
