OSX or Windows app for overlays
Re: OSX or Windows app for overlays
That's o.k. too. Now, select any lap from Lap List which is covered by the video. Press "Edit" and press "New Video". Now, select your video and follow the instructions (to select the frame matching the laps end etc).
Daniel
Post by Daniel »
Thank you. That bit I am clear with. I've previously done them using ifunbox etc to copy the videos over. ios 8.3 killed that.
It will work again once LapTimer v19 is out (1 week). It opens access for iFunbox and iBrowse when running iOS8.3
Daniel
Post by Daniel »
FYI, and probably a non issue once v19 is out but, this is what you get via iTunes when trying to sync images if you have iCloud photos enabled.
icloud photos
icloud photos
Screen Shot 2015-05-05 at 18.34.27.png (159.5 KiB) Viewed 9931 times
Daniel
Post by Daniel »
apologies for the image size! stupid retina display
That's not iOS specific, it seems one can use one or the other. Need to update the docs anyway...
aaronvogel
Post by aaronvogel »
Uh... Garmin Virb Edit does this. Very well actually.
http://www8.garmin.com/support/download ... sp?id=6593
You don't have to own a Virb to use it either. I actually don't. I use Harry's or other apps plus my GoPro footage. You can even combine multiple files from different cameras and sync them all.
I'm sure Harry would come up with something great, but if you're looking for something now... check it out.
How do you import data from Harry's LapTimer. The exported GPX files I tried to open failed...
the_jeby
Post by the_jeby »
Harry wrote:Currently, there is no MacOSX desktop software around doing this. The options preferred for LapTimer are Dashware and TrackVision - both PC. Time required will not necessarily be shorter (this would require hardware acceleration of video encoding integrated into the software - like iOS has), but at least the space problem is going away. I have a Harry's desktop version planned but feel it will get later this year (instead of Spring).
What about RaceRender, will it work?
araemo
Post by araemo »
Harry wrote:I have a Harry's desktop version planned but feel it will get later this year (instead of Spring).
Would this be Mac OS X only, or cross-platform mac/windows, if/when it does come out?
