Raw video folder using ibrowse
Greetings Harry! Excuse my technical incompetence. Can't seem to find it through the discussions. I'm trying to find the "raw videos" using ibrowse but can't seem to find it. Which folder and usual file name is it? Thanks so much.
Re: Raw video folder using ibrowse
Check the Documents folder in the LapTimer app folder. Raw files come with extension ".mov".
P.S. In case you have "Media" selected in the center top, switch to "Apps" first.
Above is a copy of the files in the Document Folder showing only track maps and no raw videos
- Hi Harry, when I opened the Document folder it only showed the track maps and no Raw Video files. I attached a copy of the screen below from ibrowse:
- ibrowse snipping 1.PNG (92.16 KiB) Viewed 2065 times
That's the correct directory. Either there are no raw videos in LapTimer's sandbox, or the .mov files are filtered (for whatever reason). Please start by checking the location of your videos in LapTimer's Video List. Select the one you want to transfer in check the location / source information.
