1. Is there any way to overlay an entire session of laps rather than one lap at a time?
2. When I come in from a session, I press Cancel to stop HLT. Can I overlay that last partial lap which doesn't show up on the lap list?
3. Can I export the entire raw video from the session?
4. HLT was capturing video on my iPhone 6 during a session and then stopped midway through (and not at the Start/Finish, non video functions continued normally). Any idea what might have caused this?
Deven
Video questions
Re: Video questions
1. Start with a single lap overlay. In the Overlay Configuration screen you can expand the range to a full session.
2. No, data recordings for cool down laps are purged
3. See 1, yes.
4. Incoming calls, or notifications using Alerts (instead of Banners); workaround: switch any Alert notification to Banner in iOS Settings
3. See 1, yes.
Re: Video questions
When I overlay an entire session (15-20 min, 4-6 laps), I find that the OBD data (speed, rpm) sometimes freezes midway through. If I process lap by lap, it works. v18.3.7 GP. iPhone 6, 8.1.1, 128GB with plenty free.
Deven
Deven
Re: Video questions
Sure? There has been an issue with freezing data (not only OBD, but everything except time) for lap 2 lap transitions in earlier versions, but not in the most recent. Can you please try to reproduce this behavior for a small set of data (e.g. two consecutive lap) and export these laps to .hlptrl and send it to me?
Re: Video questions
I sent you the lap data. Same problem with two consecutive laps. This was also the session where HLT stopped recording video part way through a lap.
Deven
Deven
