Compatibility
simonjpw
Compatibility
Post by simonjpw »
Is Harry's laptimer compatible with an Andoid tablet such as Acer A1-830-1838 Cd 7.9" 16Gb 16Mb Bt Android4.2?
Re: Compatibility
Please check the Android Compatibility page on www.gps-laptimer.de For Android it is pretty difficult to qualify an individual device. LapTimer's (high) requirements are met by several thousand models, no way to test every device. I usually suggest to download and test it. You can pass back any app within the first 2 hours after purchase.
simonjpw
Re: Compatibility
Post by simonjpw »
How can I tesst it without going to the track?
Re: Compatibility
You can define you own track around the block. LapTimer includes an assistant to perform this operation.
simonjpw
Re: Compatibility
Post by simonjpw »
simonjpw
Re: Compatibility
Post by simonjpw »
I did see that in your compatibility page you said that the Nexus 7 was at a disadvantage without an SDslot.
However, would it work?
Re: Compatibility
Yes, but you need to plan the right memory size if you want to record or overlay video. In case you want to record HD and FullHD video, anything below 32 GB will generate inconvenience and problems.
