Can I switch from Kilometers to miles per hour?
tomiboy
Post by tomiboy »
Tried searching with no luck
Re: Can I switch from Kilometers to miles per hour?
Actually it is straight forward. LapTimer uses the system preset usually. So if you have selected your country, it should show up with your country's preference for metric or imperial units. In case you want to override this setting, use LapTimer's Settings to change to Metric or Imperial (instead of System) as you like.
