Track Configurations?
Dubbedown
Post by Dubbedown »
I will be at New Jersey Motorsport Parkway - THUNDERBOLT this weekend. This track has 2 alternate configurations, one with and one without the chicane by Turn 2. On HLT software, I see one track listed for NJMP Thunder, how do I know which configuration it is set up for?
Re: Track Configurations?
Just downloaded it, it seems to be setup for both configurations. Certainly not the best solution as you start comparing different things, but that's the current situation. In case I split it up, I need to move all existing laps to one of them, so which configuration is the more common from your point of view?
Dubbedown
Post by Dubbedown »
Harry wrote:Hi,
I believe most run without chicane but if the current map allows both, that's fine. Don't change on my account. I know what's a "good" time for both layouts so I'm not relying on the Hall of Fame. I just wanted to make sure the current map had the correct triggers or POI.
