All of the OBD data collected from my KIWI wifi is recorded in the exported csv file but Dashware is not recognizing the columns when you open it in DW. I am sure that it is some sort of mapping issue. it used to work perfectly in v.15 when you had the seperate export for Dashware, but now it doesn't work. I have fooled around with it and trying to fix the mappings, but I can't figure it out.
any ideas?
Brian
[SOLVED] Problem with CSV file in Dashware
Re: Problem with CSV file in Dashware
Figured it out. Needed to clone hlpt data profile in dashware and uncheck the semicolon as a delimiter.
The default hlpt profile in dw has the semicolon checked so the semicolons the header record is messing it up.
