LapTimer (Standard, Pro, Trainer) v16.0.4 submitted
Dear friends of LapTimer,
I just submitted the next bug fix release. It fixes all known problems and should give a pretty stable version till the next major release (keep my fingers cross):
  • Fixed a bug when switching to front cam with low res set
  • Reduced iOS requirement to iOS 4.2 to allow older iPods to be used
  • Fixed crashes in Lap List / Lap Details
  • Fixed missing initialization of current vehicle and track
Until the release to AppStore (I doubt Apple will make it within 1 day - see 16.0.3 - again), here are two workarounds: to switch between front and rear cam, leave the video resolution setting in the default position 'High'; to not run into crashes in Lap List / Lap Details, move the Lap List tab item to one of the four visible elements: select More, select Edit, drag Lap List to one of the four positions.
Trainer 16.0.4 is available, the Pro an Standard are processing for AppStore already and will be available in a few minutes. :-)
johan6504
Re: LapTimer (Standard, Pro, Trainer) v16.0.4 submitted
Post by johan6504 »
Harry wrote:Hi,
Installed last night. For some reason it feels more stable than the earlier 16.0.x versions. I had problems with the app closing down/minimizing from time to time, but this seems to be better now.
Dubbedown
Post by Dubbedown »
Thanks Harry, just downloaded this yesterday (after my track session lol.) But happy to say I finally was able to get GoPoint BT1 + Emprum + video overlay ALL working =)
