OBD throttle information no longer captured after upgrade
khammo01
Post by khammo01 »
Hello.
Prior to 13.3, LapTimer Pro showed the throttle information for my car. (2004 MINI Cooper S)
After upgrading to 13.4, it now only shows "Throttle" in the overlay, instead of the throttle percentage.
Please let me know if you require more details.
khammo01
Re: OBD throttle information no longer captured after upgrad
Post by khammo01 »
Never mind -- I just realized it is showing a horizontal bar instead of the throttle percentage!
The Throttle view was changed from a percentage display to a field being filled with a green bar once you press the throttle. 'Throttle' is a field description only.
Example: http://www.youtube.com/watch?v=i-SF7jgbE6k
fredsiva
Post by fredsiva »
Also owning a Cooper S 2011 184bhp, can I kindly ask what OBD device you are using?
Can you tell which values you can access from the OBD, like oil temp, water temp, turbo boost?
many thanks,
Frédéric
The values read out by LapTimer are available here: http://www.gps-laptimer.de/OBD_II.html I do not know if your car delivers all of the values named, it is probably a subset.
LapTimer supports both KiwiWifi and OBDKey WLAN. As your car is new, I'd expect both will work fine.
khammo01
Post by khammo01 »
Sorry, just noticed that there are replies to this thread. I am using Kiwi Wifi.
