LapTimer (Standard,Pro,Trainer) v16.0 available on AppStore
Dear friends of LapTimer,
I just submitted version 16 for both LapTimer Standard and LapTimer Pro to AppStore. In case everything is working fine, it should get available in approximately one week. LapTimer Trainer needs to go through a separate testing and will follow in a few weeks.
As a major update, LapTimer v16 introduces a big number of changes and improvements. Please find the full list of changes below.
Code: Select all
- Major update with changes almost everywhere
- User Interface improvements
	LapTimer can be operated in landscape now (namely added landscape Timer, GPS, and other views)
	Please note: rotation is blocked while driving
	Please note: not all views are available in landscape, so turn back to portrait to get the full functionality
	Generalized recalibration detection when iPhone is rotated
	Tab bar automatically hides if not used, several views use additional space
	Allow manual operation for tab bar hiding
	Added new Video List view to allow easy video maintenance
	Added number of laps by track
	Improved hover and activity views
	'Last Max' Acceleration gadget added, 'Lap #' gadget added
	New, fancy, alert views
	Alerts auto hide after some time in case they are information only
	Added OBD speed to data recording speed diagram view (so you can compare GPS and OBD)
- Video Improvements
	Added a large button to stop video recording
	Moved video links to LapTimer's database
	Much improved video link handling including 'revert to orignal video'
	Full reference handling for videos (last link removed will allow deletion)
- Additional sensor support
	Improved sensor connect / disconnect handling
	Accelerator update rate raised to 30 Hz (by far more responsive), added expert setting to further tweak it
	Made OBD reply recognition more reliable
	Support for multiple replies from car's ECUs
	Added alternative throttle PID support for OBD
	Added gopoint BT1 and gopoint GL1 support
	Enhanced Lap Detail view by sensor information
- Export Format Improvements
	Reworked VBO export (includes better trigger compatibility, interpolates fixes to 10 Hz)
	Enhanced KML export to support lineal acceleration
	Unified standard CSV and overlaying software CSV formats, added both metric and imperial columns
	Additional export scope: export by session
	Track day and session exports work relative to lap selected
	Display number of laps exported effectively
	Added video links to .hlptrl export (allows full restore)
	Store Export Settings between sessions, allow default e-mail for export
	Improved naming scheme for exports
- More vehicle and track types
	Added bicycle support (on top of cars, karts, motorbikes)
	Track set type added, search in Tracks allows selection by track set type
- System improvements
	Significant performance improvement of Lap List
	Redesigned start-up sequence, better messages on migration / data checks
	Several memory optimization
	Option for emergency startup
- Online Racing
	After the fact submission of lap times to Hall of Fame
- More Settings
	Reworked Settings grouping, moved some Expert Settings to Settings
	Added setting to trigger at low speeds
- Others
	Startup sound (turn off sounds to get rid of it)
	Pro upgraded Standard apps mimic the Pro app even more (About View)
	Added a 'Set Reference' button for continuity racing
	Dozens of smaller fixes and UI improvements
I have worked hard on this one, especially on the landscape support. Hope you will like it like I do :-)
P.S. German version below
Code: Select all
- Grosses Update mit Verbesserungen in fast allen Bereichen
- Verbesserte Benutzer Schnittstelle
	LapTimer kann nun auch im Querformat betrieben werden
	Bitte beachten: Rotation ist nur im Stillstand möglich
	Bitte beachten: nicht alle Ansichten sind im Querformat verfügbar, voller Funktionsumfang nur in Portrait
	Verallgemeinerung der Kalibrierung des Beschleunigungssensors beim Wechseln der Ansicht
	Tab Bar wird automatisch ausgeblendet um zusätzlichen Platz für Anzeigen zu haben
	Tab Bar kann aber auch manuell ein-/ausgeblendet werden
	Neue Video Liste um die Verwaltung zu erleichtern
	Anzahl der Runden pro Strecke hinzugefügt
	Verbesserte Konfigurationsanzeigen und Dialoge
	Letzte Maximalbeschleunigung wird angezeigt
	Aktuelle Rundenzahl innerhalb der aktuellen Session wird angezeigt
	Neue, hübsche Informationen und Warnhinweise
	Bei der Datenanalyse werden GPS und OBD Geschwindigkeit gleichzeitig angezeigt
- Video Verbesserungen
	Grossen Button zum beenden der Videoaufzeichnung hinzugefügt
	Video Links sind nun Bestandteil der Datenbank
	Stark verbessertes Handling der Verbindung von Data Recording und Videos
	Zurücksetzen auf Originalvideo ohne manuelle Neusynchronisation
	Nicht mehr benötigte Videos werden von LapTimer (nach Nachfrage) gelöscht
	Kristische Fehler der bei Unterbrechung des Programms zum Verlust von Videos führte behoben
- Zusätzlicher Sensor Support
	Verbessertes Verbindunghandling
	Update Rate des Beschleunigungssensors erhöht und einstellbar gemacht
	Viele Ergänzungen des OBD Parsers (multiple replies, etc)
	Alternative PIDs für Gaspedal (BMW Modelle)
	gopoint BT1 und gopoint GL1 UNterstützung
	Sensordaten werden nun auch in den Rundendetails angezeigt
- Erweiterungen der Export Format
	VBO Export stark überarbeitet (bessere Trigger Kompatibilität, Interpolation auf 10 Hz)
	KML Export inklusive Längsbeschleunigung
	Vereinheitlichung und Erweiterung der CSV Exporten
	Zusätzliche Exportgruppierung: Session
	Track Days und Sessions werden relativ zur Auswahl exportiert (statt die Letzten)
	Anzahl der effektiv exportierten Runden wird angezeigt
	HLPTRL Export um Video Links ergänzt
	Export Einstellung werden gespeichert
	Verbessertes Namenschema für Exports
- Mehr Fahrzeug und POI Gruppen Typen
	Support für Fahrräder hinzugefügt (jetzt also Autos, Karts, Motorräder, Fahrräder)
	Strecken Typen hinzugefügt und bei Suche auswählbar
- System Verbesserungen
	Runden Liste ist signifikant schneller
	Start Sequenz neu ausgelegt, verbesserte Meldungen zu Migration etc.
	Verschiedene Speicheroptimierungen
	Option für "Clean Start" hinzugefügt (Emergency Startup)
- Online Racing
	Rundenzeiten können nachträglich an den Server geschickt werden (Bestenliste)
- Mehr Einstellungen
	Gruppierung der Einstellungen überarbeitet (Expert - Standard)
	Neue Einstellung für die Erkennung von Triggern auch bei niedriger Geschwindigkeit
- Sonstiges
	Startup Sound (Ton in Einstellungen abstellen wenn das nervt)
	Standard Version mit Pro Erweiterungen optisch an Pro Version angeglichen
	Button für Setzrunde hinzugefügt
	Dutzende kleinere Verbesserungen und Fehlerbehebungen
lunat1ck
Re: LapTimer (Standard,Pro) v16.0 submitted to AppStore
Post by lunat1ck »
I'm probably wasting my time by checking the AppStore every hour.... But I am really looking forward to giving v16 a test run.
Harry, what's the typical turn around time for approval on the App Store? A few days?
Now watch the new version show up in the app store 5 minutes after I post this.... :-P
lunat1ck
Post by lunat1ck »
Gee, maybe I should like..... read your post. I jumped to the features list, and missed the part about the submission taking one week.
My bad!! Sorry for the noise....
tekyguy
Post by tekyguy »
Woo hooo! I am very excited for this release and just ordered my Gopoint BT1 :D
Dubbedown
Post by Dubbedown »
tekyguy wrote:Woo hooo! I am very excited for this release and just ordered my Gopoint BT1 :D
me too! the gopoint arrived yesterday =D
KiSwiSje
Post by KiSwiSje »
woot! can't wait!
i have a bunch of laps stored, still linked to the raw video. Do i need to overlay them before upgrading?
KiSwiSje wrote:woot! can't wait!
Actually it is better you wait with overlaying until v16 is available. v16 will store the raw video link when a lap is overlaid so you have a convenient way to switch back using it. Once v15 overlaid a video, the original link needs to be restored manually if needed...
I submitted v16.0.1 of LapTimer Trainer in addition - just a few minutes ago. It come with the named feature set announced above - but without landscape support. Landscape support is difficult as all the nice gadgets all LapTimer versions feature do not match the iPad landscape aspect ratio. So I'd need to rework too much currently.
Nevertheless, that should be a big and nice update for Trainer users too - enjoy!
Dear friends of Harry's LapTimer. Version 16.0 for both the Standard and Pro editions have been approved a few minutes ago. The are - or will be in a few minutes - available on AppStore now. As always, both versions are free upgrades for my existing clients. Wish you all the best and have fun with this new version! :-)
Dubbedown
Post by Dubbedown »
Harry wrote:Dear friends of Harry's LapTimer. Version 16.0 for both the Standard and Pro editions have been approved a few minutes ago. The are - or will be in a few minutes - available on AppStore now. As always, both versions are free upgrades for my existing clients. Wish you all the best and have fun with this new version! :-)
Downloading as I type this! Been checking my App Store Update every few hours lol!!!
