Vehicle List - Max Speed for each gear
paulinwales
Post by paulinwales »
Hi, Just finished setting up a car and I had something that caused me much head-scratching. The gear ratios and final drive were all entered correctly and I checked them from multiple sources to make sure but the displayed max speeds were all lower than they should be.
it appears the max speed in each gears are using the rpm figure from the "max power" section rather than the figure entered into the max rpm box.
That has been discussed several times in the forum. Yes, speed displayed is the speed at max power rpm currently. V16 will change that to use max rpm. I'm sure there will be discussions on it nevertheless...
