[SOLVED] Vehicle list help
rscliofan
Post by rscliofan »
ok so i'm struggling, mainly as i have a car that only 50 were produced.
do can someone tell me what "shift flash %" is?
also in power transmission
i can only find the following info on my drive
Vehicle speeds mph @
1,000 rpm (ratio)
1st
13/40
2nd
19/37
3rd
31/43
4th
38/39
5th
38/31
6th
46/31
Final Drive
17/67 = 0.2388
how does that translate into HLT?
rscliofan
Re: Vehicle list help
Post by rscliofan »
ok i think i've got my drive and gear ratio but what is shift flash %
That's the threshold of RPM you want LapTimer to start showing the shift flash. So if your car's max RPM is 10000 (easy to calculate) and shift flash is 90%, LT will start flashing at 9000. Please note all of this makes sense with an OBD sensor connected only.
rscliofan
Post by rscliofan »
arrr i see, my car already has a built in shift light and audible beep that can be adjusted.
Thank you.
This app is just soooooooo good.
and v16 looks even better!
rscliofan
Post by rscliofan »
Ok i'm still having issues in that OBD Data isn't showing the right gear but i'm also unable to get the right settings?
if you look at the image bellow you will see V15 and V16 beta. you will see the gear ratios are EXACTLY the same as the rest of the car settings are but the speeds are different????
Neither show me in the same gear as i am in most of the time though? no biggie just would like to sort it out if i can?
I should ass that V16 is almost spot on just a few mph out but V15 is way, way, way out with the same settings :?
v15 shows the speed at max power rpm (5500), v16 shows the speed at max rpm the engine can make (limit = limiter). The later has a certain meaning, the first one is a good approximation for the vehicle's max speed IN CASE IT HAS NO FUEL SAVING LAST GEAR OR IS A DIESEL ENGINE. As there are too many cars that do not fulfill this criteria and generated lots of questions here on the forum and in my mailbox, I decided to change it.
rscliofan
Post by rscliofan »
Thank you harry.
It is now showing the same.
rscliofan
Post by rscliofan »
V15 now works perfectly.
