New Track Created Has Vanished
MSGios
Post by MSGios »
I have created a new track on Harry's Lap Timer.
Did several laps and all the lap times were recorded and they are saved in the app.
But the track itself is no longer in the app.
I can see the laps under the track name, but the track is not there anymore.
It already happened twice.
Previously I erased everything related to the new track, recreated it and did several laps (that are still in the app). Went back to the created track couple of days later and the chronograph did not start at the starting point - then I found that the track data were not there anymore.
I have 3 previously creates tracks that are still available in the app - but the recent created one dispeared.
What might be the problem?
Thank you,
Marcelo Gios
PS: I create the track in order to practice to a closed track rallye that took place last sunday at Interlagos - SP, BRAZIL. I am the only on using Harry's. Everybody else is using Race Chrono. I beat then all!
Re: New Track Created Has Vanished
Answered to your mail.
CoreForce
Post by CoreForce »
I'd like to learn about it as well, if possible?
CoreForce wrote: Fri May 16, 2025 10:25 am I'd like to learn about it as well, if possible?
Track definitions are saved when LapTimer is sent to background / getting inactive. So you can make sure your custom tracks are saved as follows: press Home button or use the corresponding swipe operation. Make sure you are on Springboard or in any other app for 10 seconds. Return to LapTimer. In case you do not get the startup screen (which means the app has crashed and is restarted) and the Custom Track set is in Lap List, it will stay there permanently. In case it is not, we need to investigate what causes a crash.
