OBD data in Dyno reports
Posted: Mon Jan 06, 2025 10:29 am
by R-power
dear Harald.
many congrats for your apps
i am having fun with your Dyno app (in order to check with friends if the modification of our GR yaris are effective or not using for example 100-200kmh time)
Your app is fantastic because it permit to use personal GPS antenna without having necessity to buy a dedicated one.
I have XPS160 and Racebox mini. both working
But in addition you have OBD data (i have obdlink mx+ dongle)
I have some questions:
1. does the features in harry-lap-timer-granprix are the same of this ??
2. in harry is it possible to have video of the run with overlay ?
3. in case is it possible to have it as addition in dyno ?
4. is it possible to have reports as the classical dragy or pgear apps ?
5. is it possible to visualize in reports also OBD data (rpm for example, to understand if with acceleration and time progression there can be an optimal rpm to change gear)
sorry to disturb you and thx so much
ivo from italy
Re: OBD data in Dyno reports
Posted: Sun Jan 12, 2025 2:20 pm
The Dyno features & functions are fully available in LapTimer GrandPrix. While a direct video start / stop function is not available from GrandPrix's Performance view, you can add external footage to LapTimer "after the fact" and overlay the recording data. While it could be done, LapTimer's overlay will use the track scenario gauges, nothing special like like a speed / time diagram.
It might be possible to enabled video recording in Timer view, and switch to Performance view afterwards to get footage recorded directly. But I have to add - I have never tested this. :-)
