Inconsistent GNSS Data Accuracy with External Sensors
Posted: Thu Nov 28, 2024 12:20 pm
Hello
I have been facing inconsistent data accuracy when using an external GNSS sensor with Harry's LapTimer. During high-speed laps; the location precision occasionally drops significantly; even under clear sky conditions. This leads to inaccuracies in lap timing and GPS traces; affecting overall reliability.
I am using a Qstarz BL-1000GT GNSS sensor; with all settings configured according to the user manual. I have checked viewforum.php?f=19msbi guide for reference .
Could this issue be related to sensor compatibility, firmware configuration, or possible interference from nearby devices? Additionally; would adjusting the GNSS update rate (e.g., from 10 Hz to 5 Hz) or tweaking phone settings improve stability?
I would appreciate any advice to optimize the performance of my setup.
Thank you !
Thank you !
