bluetooth transfer not possible.
neo9596
Post by neo9596 »
Hi, thanks about your app, i've tried to transfer a track from my iphone to my ipad and it's not possible, a window is shown looking for devices but the iphone doesn't see the ipad and viceversa.
Do you know where is the problem?
Thanks.
Re: bluetooth transfer not possible.
Just tested it between an iPhone running a 13.3 and an iPad running Trainer 13.1. Worked as expected...
Please check you have enabled bluetooth on both devices. And: sometime it takes quite some time until both devices detect each other.
neo9596
Post by neo9596 »
I tried an Iphone running pro version 13.3 and an ipad with the same version, both with ios 4.3.1.
Thanks.
And did it work or not? Have you checked your Bluetooth status?
neo9596
Post by neo9596 »
It didn't works, the bluetooth is on, I see the pc and the external gps, but the idevices seems blind.
I follow these steps:
1: bluetooth "on" on both devices.
2: now I open the laptimer on both devices.
3: go to send, and a window appear looking for devices and no device is found.
may be I do something wrong?
Thanks for your attention.
In addition to sending from one device, you need to prepare the receiving device:
On the receiving device, you need to go to the Lap List, press the button in the top left, and select 'Receive Lap from Friend'.
Please check the site http://web.me.com/hschlangmann/LapTimer ... ainer.html in addition. It has a step by step description.
neo9596
Post by neo9596 »
oh!!! thanks, that's was, I was sure I did something wrong and did not find a tutorial on how to transfer files via bluetooth in the section of laptimer so i did not read the trainer tutorial because I thougt It was a different product, maybe a link in laptimer section on how to transfer will help. Thanks for your time helping me.
Now I can prepare the circuit in the ipad with a bigger screen and transfer it to my iphone, that's perfect, and i encourage you to keep working on this great app!!.
