track configuration display
Bobl36
Post by Bobl36 »
I'm not sure if I can describe this clearly, but using Gran Prix, the image of the track displays only a partial view of the track. I used to have the entire course map on the display, I don't know what I did to change this, what should I do now?
Can/should I delete old POI's? Our region has used the same lot venue for all autocross events for at least the last ten years, will that accumulation of POIs cause any sort of conflict or problem with starts and finishes?
I have an "extra" android I would like to include in the mix, can add this without paying for two devices?
Also, I have not been racing for a couple of years and haven't used Laptimer for quite a while and will probably have some simple questions, like this, come up as I get back into the fun.
Re: track configuration display
Please let me know which display you are mentioning? In Online View or a video overlay?
Track sets must not overlap. You need to delete conflicting track sets. This is done from Lap List: navigate to the track configuration and find the row saying "User defined track set" or "Certified track set". Long press that row to delete it. Laps recorded using the track set will not be removed.
App licenses are bound to Apple / Google IDs, not a specific phone.
