Android radio?
j91z28d1
Android radio?
Post by j91z28d1 »
there's a new android based radio out for c6 corvettes. it has 3 total video inputs. backup, front and a dash cam. currently I believe only the dash cam is mean to be saved to an SD car.
but being android would it be possible for this app to run on the radio itself? it has GPS and wifi for data if needed from a phone hot spot.
be very really nice to load your app on the radio and beable to record and sync up the 3 video inputs.
do you think this is possible?
it's a pricey radio and being about to do that would make it eaiser to justify haha.
Re: Android radio?
I have seen several tests of in car Android devices the last years. My impression is that most miss some feature required by LapTimer to work. This is mainly about access to a cam (if any) and GPS. You can check everything except video / cam by installing the free Harry's GPS Buddy. In case it works (check the GPS View in particular), LapTimer will too. Cam access can be tested with LapTimer Petrolhead / GP only.
j91z28d1
Re: Android radio?
Post by j91z28d1 »
thank you for the reply.
once I get it installed I will try.
