Suggest that the mobile phone's video recording feature allows switching to a wide-angle lens
redeemer
Post by redeemer »
Currently, many smartphones are equipped with both a primary camera and a wide-angle camera. It is suggested that there should be an option to switch to the wide-angle camera for better video recording quality.
Re: Suggest that the mobile phone's video recording feature allows switching to a wide-angle lens
Please goto LapTimer ‣ Race ‣ Timer and enable the internal cam for recording. Tap the Preview button which will lead you to the cam view. In the top left, you can switch through all cam angles selectable. For my phone (iPhone 15 Pro Max) , this includes the ultra wide angle lense.
redeemer
Post by redeemer »
Harry wrote: Thu Apr 25, 2024 11:55 am Please goto LapTimer ‣ Race ‣ Timer and enable the internal cam for recording. Tap the Preview button which will lead you to the cam view. In the top left, you can switch through all cam angles selectable. For my phone (iPhone 15 Pro Max) , this includes the ultra wide angle lense.
There is no button to switch the camera lens in the upper left corner, only a button to switch the resolution.
. I am using an Android phone, the iQOO 12 Pro, but I can see the option to switch to the wide-angle lens in my camera interface.
O.k., Android. As the cam interface for Android is inconsistent across vendors, LapTimer's Android version allows changing between front and rear cam as well as resolution only.
EthanFinn
Post by EthanFinn »
It's true that having the option to switch to a wide-angle camera for video recording on smartphones would greatly improve the quality of the videos fnaf This feature would provide users with more versatility and better capture capabilities.
