new VBOX Sport (2024)
Sledgehammer
Post by Sledgehammer »
there's a new VBOX Sport Version that supports 25 Hz rate. Will it be supported by your Laptimer? If yes, can you predict when?
Thanks in advance ...
Re: new VBOX Sport (2024)
Thanks for pointing me to this. I will contact Racelogic and check whether they changed the API. In case it is unchanged, the change to a higher rate should be no problem.
oldnick
Post by oldnick »
Hallo,
any news on the compatibility of the Vbox sport V3 at 25Hz (or update required)?
thank you !
I contacted RL on this, no reply so far. :-( Maybe someone with a device can give feedback...
bobneids
Post by bobneids »
hey all - thinking about going with a Vbox sport V3, but wondering if anyone had luck with these integrating with the laptimer.
I will only be running an external GPS and GoPoint BT1 OBD connector.
Thanks, Bob
aMacUzr
Post by aMacUzr »
You could look at a RaceCapture unit as an alternative. Works well with HLT.
