[PLEASE READ] LapTimer Versions 15.0.5 available on AppStore
LapTimer version 15.0.5 just arrived in AppStore for all LapTimer versions.
  • Added a recovery function for a bug introduced in v15: in case LapTimer showed lap times, but no GPS plot, this will most probably be recovered now. To run the function, press 'Check Data' from LapTimer's Lap LIst.
  • Widened the trigger detection corridor for high precision external GPSes. This issue has been reported by several users - LapTimer has been too picky with triggers while using external GPSes.
Please make sure you run the data check named first. Hope this will finally have everything fixed in the database area. :(
