Andriod 13 & Garmin glo2 connection issue
Posted: Fri May 19, 2023 8:58 am
Morning Guys,
I cant connect my GLO to my phone, once paired it drops to 'Peiviously connected devices' and cant be selected. it does the same in lap timer. where it shows up but cannot be selected, just says 'not availible'
if i use the third party app i can connect laptimer via the 'Pixel sensor' (goes from 1hz to 5hz when using the GLO in the background) alothught laptimer disconnects the GLO and reverts to the phones sensor. when using maps. the GLO will stay connected, and provide very good GPS location data.
should I beable to select laptimer as a 'mock location provier' ? as to me with my limited knowledge this would solve it as the thridparty app needs this to connect to the GLO.
phone is a PIxel 6a
GLO firmwire is the latest.
im not sure how but i did beifly have laptimer conected to the GLO last night but i needed the thirdparty app running, (it was proving 9hz data) however i cant repeat that this moring. (was going to test it on my way into work)
phone is a PIxel 6a
