G meter miss reading
Posted: Thu Sep 01, 2022 7:26 am
by Mike S2k
Hi is it possible to adjust the gmeter after the recording. I noticed that the g meter over reads on right hand corners. I was using a XGPS160.
Please see video.
Thank you!
https://youtu.be/7DUjMbHnaPI
Re: G meter miss reading
Posted: Thu Sep 01, 2022 7:30 am
Yes. Please select the lap from Lap List and follow Data Recordings / Charts. Swipe to the G-G diagram. Use the blue buttons to rotate acceleration vectors as required.
Posted: Thu Sep 01, 2022 5:45 pm
by Mike S2k
Thank you for the quick reply. I had a look and found the data charts you mean however it looks complicated and I don’t want to mess anything up as it’s my best lap.
Posted: Thu Sep 01, 2022 6:38 pm
All of this functions are non-destructive, so you can play with them. Or post a screenshot here, and I will tell you what to do. You will need the rotation functions in the bottom. The one marked with an A will auto-rotate.
Posted: Mon Sep 05, 2022 11:14 am
by Mike S2k
Thanks, had another quick look. If I was to press the auto rotate once would that fix it?
Posted: Mon Sep 05, 2022 12:58 pm
In case the acceleration vector is slightly rotated (like you your video) - yes.
