Which map to load
andwat
Which map to load
Post by andwat »
Literally installed this app 20 min ago. I will be heading to Nürburgring. There are multiple maps
for this track. If I select the FULL circuit config, will the app know which configuration I am doing based on GPS?
Or do I only load 1 config?
Re: Which map to load
This answer will be late, I'm sorry.
LapTimer selects whichever track set is loaded when passing a trigger defined in that track set. For tracks with multiple track configurations, LapTimer will not select the correct one automatically. You need to do this yourself and make sure that other configuration for that track are purged to not confuse LapTimer. LapTimer will prompt you on conflicts when loading a second configuration for the same track.
