Page 1 of 2
external GPS sensor
Posted: Fri Jul 22, 2022 6:20 pm
by petermbooth
When using an external GPS on a race motorcycle, does the GPS device need to be connected to my iPhone running HLT? (Or can I do my laps with just the GPS and then import the data to HLT after I'm done racing?)
If I need to have both the GPS and my iPhone on the bike, can that connection be bluetooth?
Re: external GPS sensor
Posted: Sat Jul 23, 2022 6:29 pm
LapTimer imports GPX files. So in case your GPS logger is able to record and export this format, LapTimer will be able to import it and split it into laps. I can't help with brands / models, but they may exist.
The default setup with LapTimer is either the smartphone or the smartphone plus sensor mounted to your bike. This is working well but needs preparation.
Posted: Mon Aug 22, 2022 1:43 pm
by Bleak December
Hi!
This is my first post, so hello everyone!
I am planning my first track day and have been eyeing Harry’s Suite as I think is the most powerful out there. I think I will be getting the Grand Prix edition as would like to add the HR to my overlay (off-topic sorry), but regarding the external GPS, how can i confirm the list of supported devices?
Thank you!
Posted: Mon Aug 22, 2022 2:44 pm
Posted: Mon Aug 22, 2022 3:40 pm
by Bleak December
Thank you!
Posted: Mon Aug 29, 2022 10:12 pm
by Bleak December
I have a dragy laying around. Is compatibility integration for this GPS on the roadmap Harry?
Posted: Tue Aug 30, 2022 6:45 am
There is no out of the box integration available currently. It has a BT4 interface, so it might be connectable using LapTimer’s Custom BT GPS Adapter feature, but this needs to be tested. You need to contact the manufacturer and ask for a technical interface description to check that.
Posted: Tue Aug 30, 2022 7:17 am
by Bleak December
Hi Harry
I am happy to help and contribute to the community and chase those guys, although I am not quite sure about what to ask exactly. What is behind the description of the technical interface? What parameters should I ask for, it’s like they have to provide part of the code?
Thank you!
Posted: Tue Aug 30, 2022 7:33 am
Ask them whether they stream GPS data for 3rd party apps. In case they do, ask for the protocol used as well as the BT LE interface (GATT). I can't say if I or others have contacted them before, there are so many. ;-)
Posted: Tue Aug 30, 2022 4:23 pm
by Bleak December
One more won’t harm :roll:
Have contacted them already, hope they come back to me with an answer, whether is a yes or no!
Cheers,
Bleak
