Standing Go Trigger
Nevtiger
Standing Go Trigger
Post by Nevtiger »
I use Lap Timer for UK Hillclimbs and Sprints.
The system works well as log as i get the trigger points in the correct place.
However, the Start of each run is slightly missed as it takes the system i small while to acknowledge i have started accelerating.
Is it possible to have the system record the - for example - 5 seconds prior to the actual start?
Cheers
Nev
Re: Standing Go Trigger
Please have a look into this FAQ: viewtopic.php?f=39&t=5652
In case it doesn't give an answer, please let me know.
Nevtiger
Post by Nevtiger »
Yes and No.
Yes i have confidence that the times etc recorded are accurate.
No: What i was referring to, badly in hindsight, is the video recording. I.e. is it possible for the system to include the 5 seconds prior to Launch?
Thank you for the answers.
Cheers
Nev
O.k., video. For position triggers, one can enable manual timing in LapTimer's Settings, start a manual recording (including video) and drive. Passing a trigger will stop the manual recording and start an automatic recording. For standing go triggers, this will not work because LapTimer will not go into charged state.
Nevtiger
Post by Nevtiger »
Ok, thank you for clearing it up for me
Nev
