Overlay Not Copying Over & Turning into Slow motion
Brian252
Post by Brian252 »
Recorded laps on Lap Timer, recorded video separately on Go Pro 8. Added video to Lap Timer via iTunes. Everything looks good in the App. Overlay the videos and everything previews well and is accurate. Once I try to export, the phone freezes but as long as I leave it alone, it says it successfully downloads to iPhone. When I go to view on iPhone, the track overlay is gone, so it looks like the raw video again, but also into the first lap, it shifts into slow motion for the rest of the video. I have tried many things to make it work and I cannot get it to copy over the overlay.
My workround is to screen record the session but that doesn't give me the best resolution.
I believe I recorded the laps in 1080p/240hz if that helps at all.
Using iOS 15.5
Re: Overlay Not Copying Over & Turning into Slow motion
240 Hz cannot be processed by LapTimer. Internat processing is done in hundreds seconds, so the max rate it 60 Hz. Using 240 Hz, the video will stutter or show other issues.
