Turbo Boost not recorded in exported data
drein1
Post by drein1 »
With my 2017 718 Porsche Cayman (and OBDLink MX BT adapter), LapTimer shows the turbo widget and its changing values, but when I exported it, I don't get any boost columns, where I'm fairly sure I was it with my older Audi TT. How do I get that value? Along the same lines, the app shows braking, but that is not exported either.
Thanks in advance for any help!
Re: Turbo Boost not recorded in exported data
The parameter you are looking for is MAP (manifold air pressure). It is exported to .hlptrl and .csv but not the other formats.
drein1
Post by drein1 »
Great! What about the braking value?
For most cars, braking is derived from other parameters. This is done in real time in LapTimer. These values are not exported (as they can be derived again).
