How to transfer tracks and cars between iphones?
nmartinez
Post by nmartinez »
Hi harry,
i need your help.
I creat a:
- hillclimb Track
- diferent Cars
in my Iphone 4S and now i want to share it with 2 different drivers so they can go to track and compare the lap-times...
How can i do that without having to make/transfer a lap-time?
I also want to transfer to/from ipad - Trainer version.
If i export to email i don't know how to open it?
I also don't know how use drop-box...
Is possible to see online mode on a track made by me (not on official list)?
To mark the middle sectors of the track should i use "POI Type: Trigger" or "POI Type: Information", both register "Gap" times???
Best Regards,
Nuno
Re: How to transfer tracks and cars between iphones?
Hi Nuno,
You need to export your cars (Vehicle Details->Export) and send it to your friends. You friend open the mail on their iPhone and long-press the attachments. Finally, they select LapTimer to open it. For tracks, you use the Certify function and the send the file to your friends instead of sending it to me.
Drop Box is one way (export) only.
Online view for uncertified tracks is limited. You will see your track once you have at least one lap driven, but the Lap List shown within Online View will show all times on ANY uncertified track driven.
To define a split trigger you select General Type: Trigger and Trigger Type: Split (it is in the bottom of the screen.
Hope that helps.
nmartinez
Post by nmartinez »
Thanks Harry!
Is possible to you certificy a European hill climb track?
Our first race is on FALPERRA - Portugal, and our race cars will have your laptimer instaled.
Help me setup de "Direction" on the trigger, please...
Best Regards,
Nuno
Absolutely. The only thing I'd like to have is that track sets certified are of general use for others too.
The 'Directions' is for optic reasons only. In case direction is set to something different than '0', the direction is used to draw a line across the track instead of just showing a flag. Directions used are =0° for North, 90° for West and so on.
nmartinez
Post by nmartinez »
Hi harry, help me to certified a track... step by step...
Nuno
Here is the background story on triggers - you should read it first: http://www.gps-laptimer.de/Trigger_Logik.html
Secondly, here is the description of track sets including a small tutorial: http://www.gps-laptimer.de/Tracks.html
