How to approach a changed track
francesco
Post by francesco »
Tomorrow I will drive on the new GP circuit of Zandvoort.
The POI are expected to be the same (corners do not change, although some might be a bit wider). But the start/finish (trigger) is expected to be changed.
How to approach this? Start with a new circuit or select the latest certified 2011 version and update afterwards?
Would like to contribute to update the track to the GP 2020 version!
Image Image
Re: How to approach a changed track
Please purge the old Zandvoort POIs first. You can find them here: LapTimer ‣ Analysis ‣ Lap List ‣ Zandvoort 2011. Swipe (iOS) / long press (Android) the row "Certified Track Set" and select Delete. This is making sure you will not run into conflicts.
Once you are on site, please setup a new track "Zandvoort 2020" using LapTimer ‣ Prepare Race ‣ New Track.
Once you are back home, please export your Zandvoort 2020 recordings to HLPTRL and KML and send them to Tracks@gps-laptimer.de. Please add a note "changed POIs for Zandvoort 2020 configuration".
We will add that configuration based on your input and provide a certified track set you can load after the fact.
Thanks, Harry
