RPM into Harry without OBD
larskleppe
Post by larskleppe »
Hello, are there any possibilities to get analog RPM signal into Harry's Laptimer on an old car without OBD. Are there any simple sensor available? / Lars
Re: RPM into Harry without OBD
To my knowledge, Autosport’s Race Capture Pro series can use individual Hall sensors to measure RPM.
rkanaga
Post by rkanaga »
Hi I would like to add sensors for steering angle, rpm, throttle position and brake pressure (plus possibly wheel speed). My car does not have OBD II as it has a non standard ECU (GEMS).
Can all of this be done using Autosports Race Capture? How would I get the data from the Race logger into Harry's Lap Timer to integrate with the other DATA (GPS, accelerometer video etc)? Have you worked with any other types of external sensor to provide car data?
Thank you very much
