Petrolhead 23.0.10 crashing on iOS 13.2
Posted: Thu Oct 31, 2019 11:23 pm
by dougidleracing
I had to reinstall the app today, version 23.0.10, on my iPad Pro running iOS 13.2. Unfortunately, the app is crashing. I'm unable to load either of the Karting tracks I use (Bayford Meadows and Buckmore Park) or restore from a backup file - the app just crashes.
Any idea what I can do please?
Doug
Re: Petrolhead 23.0.10 crashing on iOS 13.2
Posted: Fri Nov 01, 2019 12:14 am
I install 13.2 now and will check if I can reproduce a crash.
Posted: Fri Nov 01, 2019 7:28 am
Is this an iPad with mobile Internet option or WiFi only?
I just tried for a 11 Pro Max (13.2) and loading Bayford is working,
Posted: Fri Nov 01, 2019 7:49 am
by dougidleracing
It’s wi-if only. I checked again and I can’t load any tracks at all
As soon as I click ‘Load’ the app crashes. When I reopen it nothing has been loaded.
I can do a restore on my iPad and see if that helps. I’ve not cleaned it out in a while.
Doug
Posted: Fri Nov 01, 2019 7:50 am
I will try to reproduce it with a WiFi only device.
Posted: Fri Nov 01, 2019 7:51 am
PS. Which external GPS do you use?
Posted: Fri Nov 01, 2019 8:17 am
by dougidleracing
I’m using the Dual 150, but only with my phone. I don’t connect the iPad to it. I collect the data on the phone and then transfer it to the iPad for analysis on the bigger screen.
Are there any crash files the app saves I could send you?
Doug.
Posted: Fri Nov 01, 2019 8:22 am
The iPhone is running 13.2 too?
Provided you haven’t opted out, crash reports are sent to Apple. These get available for developers after some time.
You can send a crash log directly! Start the Settings app and follow Privacy / Analytics & Improvements / Analytics Data and select a LapTimer crash log with a date after updating to 13.2. Send it to
Harry@gps-laptimer.de and I will check.
Posted: Fri Nov 01, 2019 8:52 am
by dougidleracing
Hey Harry,
The iPhone is still running iOS 13.1.3.
I’ve sent you a crash log.
Doug
