Default FOV on GoPro Hero Silver
BenB123
Post by BenB123 »
Hey,
It looks like every time HLT connects to the GoPro (ex: Race -> Timer -> Video), the FOV is reset to "Medium". Is that something HLT is doing explicitly? Or is that how the GoPro handles remote WiFi connections? Can something be done to prevent that from happening if I want to capture in "Wide" FOV?
ben
Re: Default FOV on GoPro Hero Silver
Yes, in case you select the Master or PiP MultiCam Preset in Settings, LapTimer will adjust resolution and FoV. In case you want to keep your own settings, select No Preset / None here. Take care to chose a resolution / FoV / fps LapTimer can use.
BenB123
Post by BenB123 »
Awesome, thanks!
ben
