[SOLVED] transfer from iPhone to iPad
Posted: Tue Apr 24, 2012 9:42 pm
by BigDave
I just recently purchased the Pro version for my iPhone and the Trainer for the iPad. I absolutely love the app for the track.
I downloaded the Trainer app today and I'm unable to get a connection between the iPhone and and iPad. Bluetooth is on, single lap selected on iPhone, send button selected and iPhone is "looking" for iPad, but never finds it. If I select "track list" on the iPad the application crashes.
I would appreciate any advice to resolve this issue. BTW, iPhone 4 and iPad 2.
Regards, Dave
Re: transfer from iPhone to iPad
Posted: Tue Apr 24, 2012 9:49 pm
Hi, you need to set LT Trainer to receive mode in addition: navigate to Lap List, press the button in the top left, select "Receive Data from Friend". For more information, check out this article:
http://www.gps-laptimer.de/Trainer.html
On the Track List crash, please restart Trainer and try again. I'd appreciate you send the crash logs created to me for analysis:
http://aplus.rs/apple/how-to-find-crash ... sta-and-xp
Posted: Tue Apr 24, 2012 10:14 pm
by BigDave
Thanks for the quick response. I am unable to set Trainer in receive mode because the app crashes when I select the lap list. I tried to restart the application and I also restarted the iPad, but this did not prevent the app from crashing when I selected the track list.
I am currently updating the operating system for my iPad and once it's complete, I will send you the crash logs.
Regards, Dave
Posted: Tue Apr 24, 2012 10:20 pm
As you have probably no lap data on your iPad, you may delete / reinstall here. I will release a bug fix release 15.0.2 soon.
Posted: Wed Apr 25, 2012 11:19 am
by BigDave
Downloaded Trainer app again and no problems ... Thanks for the help and continued success with your products.
Regards, Dave
Posted: Sat Apr 28, 2012 6:44 am
by Holger3.2
Downloaded Trainer app (15.0.2) now several times. First, if i try to open Lap List the app closes... on second trial the app tries to initialize and then short messages "Check database"; "migrating Recording Database" and finally "migrating Lap#0 recording" ... than app closes already... ?!
tried it now 5 times... happens again and again in the same pattern...
thanks
holger
Posted: Sat Apr 28, 2012 6:53 am
Hi Holger,
you probably suffer from the data base corruption topic v15 introduced? Have you tried to delete the Trainer app completely before reinstalling it?
Posted: Sat Apr 28, 2012 7:24 am
by Holger3.2
Hi Harald
updated now my iPhone to 15.0.2; deleted the trainer completely (meaning i tapped the x on the icon; is there possible more?) from the pad... re-installed trainer 15.0.2 .... unfortunately now change
Holger
Posted: Sun Apr 29, 2012 6:48 pm
Just to give you the outcome of our tests: Holger had iOS 4.3.3 installed; after upgrading to iOS 5.1 it worked.
I will check what the problem with 4.3.3 is and try to fix this in the next bug fix release.
